Resolution...
noshali
Just want to know if a notebook pc display has a 1280 x 768 max. resolution or for that matter a desktop monitor. Is there a way to watch hd content. like HD movie trailers.
thanks & Regards,
rocco
Most inexpensive laptops sold today use a 1280 x 800 display. The 17" laptops are even higher.
When shopping for a replacement desktop display a few weeks ago, I didn't find any that weren't at least 1280 wide. 1280 x 1024 seemed pretty standard for the inexpensive desktop displays.
electron
Administrator
Staff member
I play HD shows on my regular analog TV all the time (640x480), no problems at all.
noshali
The notebook tha tI like has the resolution set to what I have mentioned. I can watch stuff through the vga port but wanted to know if it was possible while I was travelling.
If yes then how would i do that.
regards,
sic0048
I guess I don't understand the question.
If you have a digital tuner, you can watch "HD content" on anything, including a 20 yr old TV.
With your laptop, you can view the HD material as long as you have a digital tuner (perhaps a USB HD tuner for example). Just because your laptop isn't a natively a common HD resolution, you can watch the material and because your resolution is relatively high, you won't see a loss of quality. You might end up with Black bars or pillars however since the screen size doesn't exactly match the broadcast HD resolutions.
noshali
Hi,
Currently I have a very old monitor that does not go over 1280 x 768. When I download or watch an HD trailer 720i the video is outside the frame because of the resolution. So quicktime opens and shows me half the window. I cannot increase the resolution from the control panel. This is a concern. I do understand what everyone else is saying that older TV can do that.
Am I doing something wrong???
regards,
Chas821
noshali,
Understand that it's not just the monitor but the video card as well that's causing you headaches. If the listed possible resolutions in control panel stop at, say, 800x600 then there's very little you can do to display widescreen content. The only possibility is a more up-to-date driver for the video card. Even though the monitor is capable of displaying 1280x768, the video card is limiting your display. Also, make sure that the monitor is recognized by your system. 90 percent of the time Windows will identify a monitor as a "plug and play monitor". See if there isn't a specific driver available on the net for the monitor. I've done this in the past to deal with similar problems.
Good Luck,
Chuck
noshali
Thanks for the explanation. So if the videocard is good to go then the monitor should display it correctly???
regards,
Chas821
If the stament you made above about the monitor being able to display 1280x768 is correct then, in theory, yes. I might be able to help more if I knew the specifics. What monitor and what video card are you working with?
Chuck
Chas821
I checked the specs of this laptop and with the included embedded Intel graphics chip you can definately do widescreen HD so the ATI option is not needed.
But I am a little confused! In the previous discussions you were talking about displaying the HD trailers on an older monitor. The information I thought you would provide was the PC and monitor model information that you were having trouble with.
Chuck
