Premise Rob Rob Brun's SYSTapi voicemail and caller id
Motorola Premise
etc6849
What USB modem does everyone use with SYSTapi? If your modem isn't listed below, but support all of the SYSTapi features, please respond.
I definitely want a modem that supports voicemail and the text to speech menu system (IVR). However, I'm limited to USB since I use a small mini-ITX based PC. Will something like this work?:
http://www.usr.com/products/modem/modem-product.asp?sku=USR5637
Details:
SYSTapi is a TAPI compatible call management system for the Lantronix Premise Home Control System. SYSTapi is comprised of a .Net executable and an importable module for SYS.
Features
CallerID - notification to all instances of the Automation Browser
Voicemail – messages maybe played with the Automation Browser or by phone
Remote Access – remotely access your SYS devices via phone
Visual IVR – visually design an Interactive Voice Response system for Remote Access
Speech – uses Microsoft’s SAPI 5.1 text-to-speech
Call Blocking – block unwanted calls with standard or custom messages
Contact Management – simple contact management allows one-touch outbound dialing
Caller Notify – create one time special messages for specific callers
Requirements
Windows 200x/XP
Microsoft .Net Framework
Microsoft SAPI 5.1
Lantronix Premise Home Control System v2.x
TAPI compatible voice modem (See Tested Interfaces)
CallerID service on the connected phone line
Tested Modems and Interfaces
The following modems and TAPI interfaces have been tested and are known to work with SYSTapi:
• Way2Call Hi-Phone USB (Recommended)
• Zoom model 3025C
• BCM V.92 56K Voicemodem
• Panasonic KX-TD 816 with TSP version 1.72 (CID on EXTxxx interface only)
• US Robotics V.92
http://forums.premisesystems.net/forums/3278/ShowPost.aspx
Sorry...the only phone line I currently have is cell...will the wonderjack work?
If you use google voice at all, you should read this thread about a $49 VOIP device called OBi110:
http://www.cocoontech.com/forums/index.php?showtopic=19792&pid=162108&st=0&#entry162108
