aksor
Beaumeri
You can accomplish the same with a 555 timer to modulate the IR leds with 38Khz.
The receivers have all of the circuitry built in to amplify and demodulate the IR signal and output a logic high or low depending if the beam is broken or not
here is a link to a circuit http://electroschematics.com/782/infrared-light-barrier/ you will need to build two receivers per doorway!
The transmitter part can be rigged up with individual transistors to control multiple IR LED's
At the receiver you can ignore the the 555 timer (its used to generate the tone for the buzzer)
instead connect a transistor to the wire that would feed the reset input on the 555 timer to drive a relay then interface it to the elk input and do a software count rule.
Or you could build a missing pulse detector using a 555 timer and for each receiver and drive the relay from there
Just a another option
