I have an existing ELK MK1 system and I need help writing a rule for the doors/windows to trigger the alarm to comply with the Florida pool code. The code states:
Chapter 41‚ Section R4101‚ (17)(1)(9)
R4101.17.1.9
Where a wall of a dwelling serves as part of the barrier, one of the following shall apply:
1. All doors and windows providing direct access from the home to the pool shall be equipped with an exit alarm complying with UL 2017 that has a minimum sound pressure rating of 85 dB A at 10 feet (3048 mm). The exit alarm shall produce a continuous audible warning when the door and its screen are opened. The alarm shall sound immediately after the door is opened and be capable of being heard throughout the house during normal household activities. The alarm shall be equipped with a manual means to temporarily deactivate the alarm for a single opening. Such deactivation shall last no more than 15 seconds. The deactivation switch shall be located at least 54 inches (1372 mm) above the threshold of the door. Separate alarms are not required for each door or window if sensors wired to a central alarm sound when contact is broken at any opening.
I have figured out the rule to do the immediate alarm upon opening the door/window but I am having trouble on how to write a rule to temporarily deactivate for no longer than 15 seconds when opening is still not secure. Additionally, is there a wall keyfob deactivation or other device besides the main M1KP2 keypad that can be mounted next to the door to deactivate. Any help is greatly appreciated. Thanks so much
Mike M
R4101.17.1.9
Mike M
