Well, the wire is all pulled, and almost everything is ready for the sheetrock. The only thing I have left to get ready is all of the window and door contacts, and to pull up the wire from the basement. I spend the entire day today installing my wiring cans. Over the last few months, I have had time to get everything set up in my cans, so that I knew exactly where I needed holes in the sides. There were a couple of places I could use the standard knockouts, but most I had to punch new holes. I used an expander bit, to get a large hole for the bolt of the hole cutter, and then used the hole cutter to punch all of my holes. I then had to mount the cans, mark where the holes in the studs went, take the cans down, and drill all of those holes. I ended up hitting a few knots, and messed up my wrist from the drill getting stuck.
After drilling all those holes through the studs, both my builder and I thought it would be a good idea to put another 2x4 behind each of the ones that I drilled through. We placed the perpendicular, so that the wall on the opposite side was only pushed out 1.75 inches. This worked for me, as the other side is a hall cabinet, and it is a very short wall. This took a while...
To finish up the day, I installed a sound deadening material to the back side of the stud wall, which should help eliminate noise from that room. We are using 5/8" Type X sheetrock throughout the house, which is great for sound deadening by itself.
In the pic below, the small can is for power, the can above it is for the Elk stuff, the can to the left of the Elk one is for telephone, cable, and punchdowns for the security contacts, and the can to the right is for lighting control. I will also have a 19" rack in the room for all of the data, audio, video, and camera gear.
The box in the wall to the far left in the picture is one of a couple LCD tv boxes. They have three knockouts, one for AC power, and two for low voltage.
The other thing you can see in this picture is the ventaliation. I had them install a Panasonic whisper quiet fan in the closet, and there is a supply vant cut into the floor (right below cans). The supply is ducted to underneath the hall cabinet directly behind the wiring cans, so that the fan will pull in house air for cooling. I'll have a thermostat in this closet, which will turn the fan on and off based on temp (fan switch will be connected to lighting control).
![Wiring_Cans.jpg Wiring_Cans.jpg](https://cocoontech.com/data/attachments/1/1382-e023a8dfdbf66f4d3fe786de34dcfd6f.jpg)
