roussell
For those with HDHomeRuns: How do you receive Standard-def signals sent by your cable company? With "Extended basic" in my area Charter sends about 65 standard def NTSC channels and about 70 more that are not (they're QAM, or ATSC, I don't know...) on the same wire with no converter box needed. Some channels are the same between the two formats, but the majority are not. It's my understanding that the HDhomerun would only pickup the HD (QAM) channels and not the rest, if that's the case; what the best card/cox for the old NTSC channels that is Sage compatible?
Also, with respect to Sage; when you have a mix of tuner devices and a variety of HD extenders to access those devices, what is the user's presentation of that hodgepodge on the HD extender? Does the user just see a program grid or channel line-up with no clue where the signal is coming from or does the user have to select a specific tuner device from which to view? If the latter, how is the WAF when having to jump between SD/HD tuner devices?
Thans,
Terry
Thans,
Terry
