I've got a doorbell zone that has automation associated with it to say a message when it is tripped. It is normally closed, with a status of SECURE. My automation code from PC Access is simple:
WHEN doorbell NOT READY
THEN SAY Visitor At Front Door
The message is never said. It used to work, but stopped somewhere in the last year or so. Every now and then I try to fix it
Here's what I've tried:
- I've confirmed that if i physically disconnect one of the wires to the zone, the message is said
- I've confirmed that if i press the doorbell, the NOT READY status is set
- I can see the status change in PC Access
- I can log a message when the zone is NOT READY. The message is logged, but the message is not announced
- I can have a different zone event cause a message to be announced. For example, I can have the message said when I trip a motion detector in the pantry, which is set up as an Auxiliary zone as well.
- I've tested the voltage drop when the doorbell is pressed and when the zone is tripped.
- I've moved the zone to different areas on the panel, and to an extension panel
I just don't get it. The zone is tripped, the automation code in the block is run, other things are done, but the zone message is never said.
Any ideas?
Any ideas?
