PaulD
Thanks all for the feedback. I am pretty sure the foam used in my area is for insulation...not fire control. I will work with the guys during construction to minimize my issues. Unless some local code requires the foam approach, I am thinking that if I fill the hole with insulation and then cap it off with a bit of foam if needed, it will be much easier to remove the foam cap when needed and pull out the insulation. Then when I am done, push the insulation back in and add a new foam cap.
When I asked the question initially, I was curious if there was some neat cap/plug/etc that is available on the market to do the job easily. Apparently not.
