Hello,
Question 1:
Im trying to size my plc cabinet for install, and I can't find anything in the OPII manual. I will have every door and window with a contact for status. Some will be used for security, some just cause. The total number will be close to 60 inputs Into security. I'll be using the 16 zone expander cards (3 I think) and will have everything ran back individually. I'd like to use some contacts for light control (signal to upb switch), some will also be used for announcement through whole house audio (kids opening doors they shouldn't, also friends have some disabled children so we would want a separate mode for them. My question Is can I pull status off any of the inputs for whatever I want (I'd think this is possible with my knowledge of PLC logic) or will I need to install relays in my cabinet?
Question,
I haven't seen a single paddle in the catalog or online that will control 2 loads based on taps, without hiding another switch, or going SA split config, or scene control. Is there a double pole switch avail in single paddle design?
Thanks for your time. If there is a PDF on the controller programming, or tech capabilities, could you point me in that direction?
Thanks.
Question 1:
Question,
Thanks.
