Quixote_1
Hello!
I'm looking to build a self-flushing toilet with a twist...
I've trained my cat to use the toilet instead of a litter box, which is amazing because I don't have to deal with the smell of the box or with changing the litter. I do, however, have to flush the toilet when he uses it. If I leave for the weekend, I come back to a nasty fermenting soup of cat crap and piss which tends to stink up the place. He seems a little discontent about the situation as well.
I recently set up an unused aquarium pump in the toilet tank with a tube leading to the overflow and plugged the pump into a hydroponics timer set to run the pump for 45 seconds every 8 hours. Although it's somewhat effective at refreshing the water in the bowl and reducing the gross factor, it lacks the oomph to flush everything completely. I considered using a stronger pump until I found this cool device that I'm thinking about ordering: https://www.amazon.com/TECHO-Touchless-Toilet-Automatic-Flusher/dp/B01DO7ABHW/ref=pd_sim_sbs_60_5?ie=UTF8&dpID=51lBkpEJimL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&psc=1&refRID=P8XBJE7PVPYCJFBTC04B#productDetails
I'd have to hack it and wire it to my own system to trigger it somehow, but when I contacted the company they said that another version is in the works and they would consider my suggestion of adding some terminals that could be used to trigger it using an automation system.
My dilemmas now are what to use to detect when the toilet needs to be flushed and how to do so. My two options at the moment are a Raspberry Pi or an Arduino, but I'm favoring the Pi because it seems more versatile and if I ever want to re-purpose it, it would probably be the most useful.
Secondly, how to detect that it needs to be flushed. A simple limit switch on the seat would be useless because the cat seems to like to do this weird routine, or "dance" as I like to call it, where he runs around the apartment howling and jumping up on the seat, then down, runs around and then back on the seat again until he's ready to do his business. Limit switches and motion sensors seem to be out of the question.
I'm thinking maybe some way of beaming IR into the bowl and detecting a change in the reflected light.
Does anyone here have any better ideas before I embark on this project? Thanks!!
