I'm thinking of installing a water meter to be used for HA application (leak detection, usage monitoring, etc.). My water utility installs Sensus SR-II meters interfaced to their RF AMR/AMI system.
(The best I can tell) The Sensus meters implement a serial protocol where the AMR module polls the meter for the current usage reading. I strongly prefer this architecture over a 'pulse counting' config where the meter just closes a contact based on incremental usage.
The Sensus website indicates that the protocol is provided to system integrators for AMR/AMI interfaces.
Does anyone in the community have this spec? Has anyone reverse engineered the protocol? I see references on the web that the meter serial interface is powered by the serial protocol. Something about one of the three wires being a clock signal..... (The meter could scavenge power from the clock signal). So it's NOT a simple serial port.....
If this serial interface isn't known, are there similar water meters where the protocol is open. I don't want to use a pulse counting scheme.....
Thanks for any information.
