So we are all moved into the new house; so far things are going well with the DIY install I did during our build.
One issue is I forgot to plan for some wider gaps on a few windows. Sensors are already buried under trim. I am using Tane pills on all the windows.
I ordered some new sensors from Tane for wide gap; of course I cannot do anything with the buried sensor but the magnets on the new sensors work when positioned in the "right place."
The issue is the "right place" requires me to shim down magnet about 1/4 inch. Any recommended techniques for the shim work, keeping in mind this will be on a window that will open.
More details... the Windows crank out, the magnet will be on the windows - there space between the window and window trim I will be sticking the magnet.
Window | |
Magnet ---
Window Trim ======
Magnet stuck to bottom of window - needs to almost touch trim (shim to fill gap above magnet)
Thanks...
Window | |
Magnet ---
Window Trim ======
Thanks...
