BaduFamily
I have a couple of simple minded questions about the Elk M1XEP.
It's on my net and I'm happily using ElkRP to configurate unto the M1. All good.
I'm coming to conclude that it's not capable of handling more than one connection at a time.
>>> that's my question. Can the Elk M1XEP handle multiple TCP/IP requests in a short time frame?
I'm trying to send a packet from elsewhere for a rule to pick up.
When I do that it seems that the ElkRP drops its connection.
Beyond that I don't actually get the response from the Elk I expect. ( I think this has to do with improper termination of the ASCII string from the sender, but that's a different problem )
I also believe that the XEP is always broadcasting log events. ( I came across this idea from late night web reading. )
Is there some way to connect via a terminal and tail this log? I haven't set up any TCP accounts, but if I need to I will
