Hello everyone. My name is Brian and this is my 1st post here. I became interested in HA a few weeks ago because I am looking for a solution to manually control and override my pool filter while away from home. I originally was thinking an x10 application but then I need a server running in order to have 24/7 control no matter where I am, via the internet. So I figure if I am going to invest in something that substantial I might as well get more complex and start to automate my entire home, little by little. I have done lots of reading in the past few weeks. I have decided to utilize UPB technology instead of x10. I also want to start with a system I can expand upon. It seems most here utilize either an ELK M1G or and HAI Omni series controller. I also found the most popular software based controllers are Homeseer, CQC and Main Lobby. Now onto my question:
Why would one choose a software based controller over a hardware based controller or vice versa? Is one better than the other? Does one have more capabilities or functionality than the other? Or does one need both? It seems the software based, even with building a server to run it is a lot less expensive that an ELK or HAI controller. I have lots of pc and electronics experience so configuring a server and connecting relays and sensors is not a difficult task for me.
Like I said, I want to start small but I want to get the right setup so that I can add onto it later on. I do not want to buy something now that I can not use later. My overall goal is to control the pool, hvac in my house, some lighting, indoor and out, as well as maybe a few zones of audio, mostly outside. Things like water sensors for the basement would be cool too. I currently have a cctv and dvr system that I am not looking to integrate, at this time. I have a security system, a Napco Gemini 1632 panel that I can upgrade to the 9600 if need be. I am willing to change to a different system but from what I have read the hardware controllers are nothing more than a security panel with some expansion ports on them. Do I really need to spend 1,400 dollars for an HAI security panel?
