rayzor said:I'm really surprised to hear that people suggesting the M1 as the controller. To be honest, I have never explored that - how do I tie that into a light switch or outlet to control it? I assume this is what you are talking about vs Insteon, and then I use something else for home automation? I also assume you are talking about the J16 programmable outputs? I only see a handful of those, but I am hoping to end up with ~55 devices that are controlled in the end. How does the M1 support that?
One way to control/automate lighting is called UPB or Universal Power Bus. It is a technology that uses existing AC wiring in your house to communicate between devices installed in that system. Start by googling Simply Automated UPB and Power Control Systems.
The UPB system operates as a lighting control system independent from the Elk to control AC loads. You simply replace your existing light switches and outlets with UPB switches and outlets and then program them using software on your computer. Any UPB switch can be programmed to control any one or more UPB outlets or switches in the system.
With the UPB devices installed your Elk can communicate with and control the UPB devices through an M1 serial port to a UPB adapter that is plugged into an AC outlet where it sends commands over the AC wires to the devices.
Mike.
rayzor said:What 3rd party HA do you recommend? I do like eKeypad for me, but just wish I could customize it more for the wife. I hate that it seems that I have to sacrifice functionality for design in the HA world.
Can any of this tie into Hue/LIFX/etc... ? I really like the idea of colored lights :0
