stepper motor help
realolman
I would like to operate a component of a machine that contains a stepper motor on the test bench, for the puposes of adjustment and repair. I feel sure the OEM would frown upon this activity, so I don't think I could get much help from them.
I have an Oriental brand bipolar stepper motor with 4.5 ohms per winding. It is connected to a Sanken A2918SW motor driver. If anyone is interested the documentation is at :
stepper motor documentation
There is not as much info on this model as others. I have disconnected the stepper driver board from the rest of the component, and am enabling and phasing it with a BASIC STAMP according to the truth table on the documentation. I think I have the sequence correct because I have tried all the combinations I can think of and this one seems to be the best.
The problem is it doesn't seem to have as much torque as it should.
VBB > Vref = 39VDC, and I am using enable ,1 enable 2, and phase 1, and phase 2 . It seems to me from looking at this drawing that I should have something hooked to E1 and E2, but I don't ... should I have something hooked to E1 and E2...any suggestions on the resistor values?
thanks
__________________
You need Rs to complete the H-bridge circuit.
Maybe try a 1 ohm/2W+ resistor.
Thank you.
The diagram shows that going to ground... I suppose that means you would connect it to V ref.
Do you think any of the "sense" stuff needs to be connected?
Is Vref your negative supply lead (DC common)?
You likely should have the sense connected, but it may just be for current fold-back. It's been a good while since I worked with steppers. I was not able to find any app notes on that device, though.
Thanks for your reply
Yes, Vref is the 39 vdc common
I was hoping the sense was just for some sort of over current fold back.
Even the company data sheet has much less info on this than the other models.
