Still having trouble (PHP/HomeSeer)
pete
this is probably just a syntax thing but it's killing me . . .
I'm trying to write a form page to control my hvac system (currently run by an Appdig Leopard). I have a string of buttons (form input types) and a panel that displays current temp, set point and equipment status for the 5 zones.
I can't get the button to actually set the hs->devicestatus, see the code snip below and let me know if you can figure where I'm screwing it up . . .
Pete C
Code:
<?php
include "header.inc";
$hs = new COM("HomeSeer.Application");
$hvacMode=$hs->devicevalue("$7")
$z1SetPt=$hs->devicevalue("$8");
$z1Temp=$hs->devicevalue("$46");
$z1Pump=$hs->devicestatus("_9");
$z2SetPt=$hs->devicevalue("$9");
$z2Temp=$hs->devicevalue("$48");
$z2Pump=$hs->devicestatus("_10");
$z3SetPt=$hs->devicevalue("$10");
$z3Temp=$hs->devicevalue("$50");
$z3Pump=$hs->devicestatus("_11");
$z4SetPt=$hs->devicevalue("$11");
$z4Temp=$hs->devicevalue("$49");
$z4Pump=$hs->devicestatus("_12");
$z5SetPt=$hs->devicevalue("$12");
$z5Temp=$hs->devicevalue("$47");
$z5Pump=$hs->devicestatus("_13");
++++  THIS IS WHERE I'M LOST  +++++
if (isset($_POST"modeOff")) {
  $hs->SetDeviceValue("$7","1");
++++  THIS IS ASP CODE THAT WAS WORKING  ++++
if Request.Form("modeOff.x") <> nil then
  hs.SetDeviceValue "$7", 1
	elseif Request.Form("modeAuto.x") <> nil then
     hs.SetDeviceValue "$7", 2
	elseif Request.Form("modeHeat.x") <> nil then
     hs.SetDeviceValue "$7", 3
	elseif Request.Form("modeVent.x") <> nil then
     hs.SetDeviceValue "$7", 4
	elseif Request.Form("modeCool.x") <> nil then
     hs.SetDeviceValue "$7", 5
    end if
<form method="post" action="hvac.php">
<table width="600" border="0" cellspacing="3" cellpadding="0" id="modeButtons">
	<tr><td width="42" valign="center" align="center"><img border="0" src="images/led1On.gif" ></td></td><td width="100"><input type="image" src="images/btnOff.gif" alt="Off" border="0" name="modeOff">
  <td width="15"><td rowspan="6" valign="top" align="center" >
 	 <h1>Heat Mode Status</h1>
 	 <table width="400" border="0" cellspacing="0" cellpadding="3" id="zoneInfo">
 	 <tr align="center"><td width="150"><u><font size="+2">Zone</font></u></td><td><u><font size="+2">Temp</font></u></td><td><u><font size="+2">Set Pt</font></u></td><td><u><font size="+2">Pump</font></u></td></tr>
 	 <tr align="center"><td width="150"><font size="+2">1st Flr Front</font></td><td><font size="+2"><?php print $z2Temp ?></font></td><td><font size="+2"><?php print $z2SetPt ?></font></td><td><font size="+2"><?php print $z2Pump ?></font></td></tr>
 	 <tr align="center"><td width="150"><font size="+2">1st Flr Rear</font></td><td><font size="+2"><?php print $z4Temp ?></font></td><td><font size="+2"><?php print $z4SetPt ?></font></td><td><font size="+2"><?php print $z4Pump ?></font></td></tr>
 	 <tr align="center"><td width="150"><font size="+2">2nd Floor</font></td><td><font size="+2"><?php print $z3Temp ?></font></td><td><font size="+2"><?php print $z3SetPt ?></font></td><td><font size="+2"><?php print $z3Pump ?></font></td></tr>
 	 <tr align="center"><td width="150"><font size="+2">Garage</font></td><td><font size="+2"><?php print $z1Temp ?></font></td><td><font size="+2"><?php print $z1SetPt ?></font></td><td><font size="+2"><?php print $z1Pump ?></font></td></tr>
 	 <tr align="center"><td width="150"><font size="+2">Garage Attic</font></td><td><font size="+2"><?php print $z5Temp ?></font></td><td><font size="+2"><?php print $z5SetPt ?></font></td><td><font size="+2"><?php print $z5Pump ?></font></td></tr>
 	 </table>
      </td>
	</tr>
I assume you mean you are having trouble using SetDeviceValue, correct?
Also, there is indeed a syntax error with the POST line:
should be
if (isset($_POST['modeOff'])) {
Yes, I cant get the syntax right . . . the asp code was working in a previous attempt w/ asp, now I need the same code in PHP . . .
actually I've been messing with it and can get the hs->setdevicestatus to work now, but for some reason my form isn't working right, I'm not getting anything in $_POST . . .
here's the code so far
Code:
<?php
/*  THIS IS header.inc
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/1999/REC-html401-19991224/loose.dtd">
<html>
<head>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1">
<title>PHANy - Pete's Home Automation Network</title>
</head>
<body background="images/screen.gif" bgcolor="#808080" text="#FFFF00">
<font face="Arial, Helvetica, Geneva, sans-serif" color="#FFFF00" size="+3">
$hvacMode=$hs->devicevalue("$7");
// THESE LINES ARE NOT WORKING
if (isset($_POST['name'])) { $name= $_POST['name'];}
echo "<p>name= {$_POST['name']}</p>";
<form action="<?php echo $_SERVER['PHP_SELF'];?>" method="POST" >
  </table>
     </td>
</tr>
<tr><td width="42" valign="center" align="center"><img border="0" src="images/led2Off.gif" ></td><td width="100"><input type="image" src="images/btnAuto.gif" alt="Off" border="0" name="modeAuto">
<tr><td width="42" valign="center" align="center"><img border="0" src="images/led3Off.gif" ></td><td width="100"><input type="image" src="images/btnHeat.gif" alt="Off" border="0" name="modeHeat">
<tr><td width="42" valign="center" align="center"><img border="0" src="images/led4Off.gif" ></td><td width="100"><input type="image" src="images/btnVent.gif" alt="Off" border="0" name="modeVent">
<tr><td width="42" valign="center" align="center"><img border="0" src="images/led5Off.gif" ></td><td width="100"><input type="image" src="images/btnCool.gif" alt="Off" border="0" name="modeCool">
<tr><td width="42" valign="center" align="center"><img border="0" src="images/led6Off.gif" ></td><td width="100"><input type="image" src="images/btnFan.gif" alt="Off" border="0" name="modeFan">
 </td>
</tr>
</table>
<?php
unset($hs);
include "footer.inc";
/*  THIS IS footer.inc
</body>
</html>
thanks for all your help !
Pete C
at the beginning of your script, add the following code:
echo "<pre>";
print_r($_POST);
echo "</pre>";
This will show anything form related whenever there is data, and should help you troubleshoot your form.
