I have configured current version of STunnel on Ubuntu. I am getting an error and not sure how to fix it.
Current start up log doesn't show an error.
2017.04.21 07:35:46 LOG5[ui]: stunnel 5.30 on x86_64-pc-linux-gnu platform
2017.04.21 07:35:46 LOG5[ui]: Compiled with OpenSSL 1.0.2e 3 Dec 2015
2017.04.21 07:35:46 LOG5[ui]: Running with OpenSSL 1.0.2g 1 Mar 2016
2017.04.21 07:35:46 LOG5[ui]: Update OpenSSL shared libraries or rebuild stunnel
2017.04.21 07:35:46 LOG5[ui]: Threading
THREAD Sockets
OLL,IPv6,SYSTEMD TLS:ENGINE,FIPS,OCSP,PSK,SNI Auth$
2017.04.21 07:35:46 LOG5[ui]: Reading configuration from file /etc/stunnel/stunnel.conf
2017.04.21 07:35:46 LOG5[ui]: UTF-8 byte order mark detected
2017.04.21 07:35:46 LOG5[ui]: FIPS mode disabled
2017.04.21 07:35:46 LOG5[ui]: Configuration successful
Sending an email though does show this error such that email is not sent.
2017.04.21 07:39:13 LOG5[1]: s_connect: connected 74.125.129.108:587
2017.04.21 07:39:13 LOG5[1]: Service [gmail-smtp] connected remote server from IPOFSERVER:33792
2017.04.21 07:39:13 LOG3[1]: SSL_connect: 140770FC: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unkn$
2017.04.21 07:39:13 LOG5[1]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket
stunnel.conf is configured as follows:
; Enable support for the insecure SSLv3 protocol
; options = -NO_SSLv3
; protocol version (all, SSLv2, SSLv3, TLSv1)
; sslVersion = TLSv1
sslVersion = all
options = NO_SSLv2
Is anyone using STunnel with GMail these days?
Added one option to gmail smtp configuration:
protocol = smtp
Logs are now a bit different but still erroring out.
2017.04.21 07:57:18 LOG5[1]: Service [gmail-smtp] accepted connection from 127.0.0.1:54616
2017.04.21 07:57:18 LOG5[1]: s_connect: connected 74.125.129.109:587
2017.04.21 07:57:18 LOG5[1]: Service [gmail-smtp] connected remote server from IPOFSERVER:52288
2017.04.21 07:57:18 LOG4[1]: CERT: Pre-verification error: unable to get local issuer certificate
2017.04.21 07:57:18 LOG4[1]: Rejected by CERT at depth=2: C=US, O=GeoTrust Inc., CN=GeoTrust Global CA
2017.04.21 07:57:18 LOG3[1]: SSL_connect: 14090086: error:14090086:SSL routines:ssl3_get_server_certificate$
2017.04.21 07:57:18 LOG5[1]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket
Testing with the Wintel STunnel.
GMail SMTP is works fine with Windows. Tried again with Ubuntu and unable to get it to work.
Anyone running STunnel in Linux?
sslVersion = all
options = NO_SSLv2
protocol = smtp
