pct88
I recently turned on temperature and humidity sensor logging in HaikuHelper and find that there are occasional data dropouts from my HAI Extended Range auxiliary sensor. This causes the temperature logged to suddenly drop to very low values, then just as rapidly return to where it was. Is this a typical failure mode for these sensors? Is there a way to configure HaikuHelper to average across such intermittent failures?
I am only seeing this on one of two Extended Range sensors. The four OmniStats are also logging properly without spurious jumps in data.
I would post an example of the data dropouts but I am not allowed to paste into my messages apparently.
