So, finally, had time to implement a ST based eddystone with temp and humidity advertising so it would be compatible with my eddystone temp only sensors.vc1234 said:I think it's quite good in comparison to my case where the battery went flat after only 2 weeks. I kept reconnecting every minute to read the sensors.
Not being impressed with the battery life at all, I have measured energy consumption with an external battery, 100ohm shunt and a scope. It turns out that with my ST I have a constant base of 1 mA draw which means that a CR2032 will last less than two weeks (240mAh / 24 = 10 days). Hoping that I missed smth with power management, I re-flashed the standard ST2 firmware and observed the same 1mA constant draw, even when the sensortag is "sleeping".
Not sure what to do next. There is some info on TI forums that a defective TEMP07 (I believe mine is since its temp readings are incorrect) may cause excessive current draw. I may try and de-solder it as some folks did. Also, noticed that when the battery level is below 78-79%, the humidity sensor stops working.
