hucker
I'm in the middle of a significant remodel and the HVAC is completely changing around, of course we are in a budget crunch
... The house is two floors, 3000 ft^2 with beds upstairs, living space downstairs. I have several general options:
1) 2 zone system (2 dampers, 2 thermostats, zone controller, 1 furnace)
2) 2 independent furnaces (2 thermostats, 2 furnaces)
3) poor man's zoning (1 thermostat, controllable registers + HA system)
The ball park numbers for options 1 & 2 were similar about 4K over a single zone system. Basically system 2 is much easier to re-duct but requires a second furnace while system 1 is tough to duct and requires bigger ducts, and a $200 zone controller. System 1 also requires more soffiting to accommodate the ducting...
Option 3 is to use the regular single zone system and connect some remote-registers. Since I already have the HA system this seems like a cheap way to go though I'm not sure how this would work in practice. Something like close most downstairs registers at night and run the system 'normally'. This requires the thermostat to be upstairs. Seems tough to make work cleanly...
Are these my only options? It seems like the ROI on the 4K is an awful long time for the relatively mild climate in Seattle. Thinking beyond payback, is the evenness of the heating in a multi zoned system that much better than my home-brew compromise?
Any input would be appreciated before I pull the trigger on this...
Chuck
Chuck
