I'm trying to use the output port of an AXIS Camera to trigger an event on my elk m1. I don't understand the transistor output (pin 4) in the AXIS instructions where it says to use a diode in parallel. Below is from the axis m1054 manual explaining ports. The input port is easy the output just doesn't make since and I don't want to hurt the camera or my Elk. If I was to use a 912 relay would I still need a diode? I'd also be interested in going directly into a zone on my elk panel and use non-alarm and then create an event.
Function | Pin | Notes
3.3V DC Power | 2 | Can be used to power auxiliary equipment. Note: This pin can only be used as power out.
Digital Input | 3 | Connect to GND to activate, or leave floating (or unconnected) to deactivate.
Transistor Output | 4 | Uses an open-drain NFET transistor with the source connected to GND. If used with an external relay, a diode must be connected in parallel with the load, for protection against voltage transients.
GND | 1 | Ground
