AHL
Hi, I've just posted a quick (1 minute) TTS voice demo video.
TTS Voice Demo
For more info, please vist Acentient Software
TTS Voice Demo
TTS Voice Demo
sub main()
HS.speak "<Voice Required='Name=Microsoft Mike'>My name is Sam. I am a default Microsoft voice. "
HS.speak "<Voice Required='Name=VW Kate'>Hello, my name is Kate. I am one of the best voices for your computer. "
HS.speak "<Voice Required='Name=VW Paul'>My name is paul, and You do sound good Kate, but I think I sound pretty good as well. "
HS.speak "<Voice Required='Name=Microsoft Mike'>Wow! After listening to you two, I think I need to keep my mouth shut! "
HS.speak "<Voice Required='Name=ScanSoft Daniel_Full_22kHz'>Hello, I am daniel. Kate, you and Paul sound really good, but all of you have funny accents. "
HS.speak "<Voice Required='Name=ScanSoft Lee_Full_22kHz'>I say old chapp. It's funny you brought that up Daniel. I was thinking quite the same thing. "
end sub
Very funny!Just as an FYI, for those that are using Home Seer, it is quite easy in the scripts to change the voices. Here is an example I just put together to demonstrate (VBSCRIPT):
Code:sub main() HS.speak "<Voice Required='Name=Microsoft Mike'>My name is Sam. I am a default Microsoft voice. " HS.speak "<Voice Required='Name=VW Kate'>Hello, my name is Kate. I am one of the best voices for your computer. " HS.speak "<Voice Required='Name=VW Paul'>My name is paul, and You do sound good Kate, but I think I sound pretty good as well. " HS.speak "<Voice Required='Name=Microsoft Mike'>Wow! After listening to you two, I think I need to keep my mouth shut! " HS.speak "<Voice Required='Name=ScanSoft Daniel_Full_22kHz'>Hello, I am daniel. Kate, you and Paul sound really good, but all of you have funny accents. " HS.speak "<Voice Required='Name=ScanSoft Lee_Full_22kHz'>I say old chapp. It's funny you brought that up Daniel. I was thinking quite the same thing. " end sub
You can if you use one of the Elk plugins with HomeSeer. There is no limit to the text that HomeSeer can speak. It will speak what you type as long as you type.It'd be great for Elk M1 Gold to tell a program, such as HomeSeer, to have the speech synthesizer speak out, instead of using very-limited 500-word vocabulary built into Elk M1 Gold. For a guest that arrived at the front door and pressed the doorbell button, I'd have to choose words carefully and the best way I can come up is "a guest is at front door." But with a computer's software speech synthesizer, I can have them say "a guest has arrived." There's no "arrived," in Elk M1 Gold's list of voice vocabulary words.
So anyway, software speech synthesizer is very handy for me!
Keep in mind that while the 500 word built in single voice vocabulary may sound boring and limiting, it is light years ahead of the panels with no voice at all. A large percentage of Elks customers do not use pc's or other software programs so the built in voice is awesome for them. Absolutely agree if you are little more hi-tech and have a software solution that full TTS will work better than Elk's built in.It'd be great for Elk M1 Gold to tell a program, such as HomeSeer, to have the speech synthesizer speak out, instead of using very-limited 500-word vocabulary built into Elk M1 Gold. For a guest that arrived at the front door and pressed the doorbell button, I'd have to choose words carefully and the best way I can come up is "a guest is at front door." But with a computer's software speech synthesizer, I can have them say "a guest has arrived." There's no "arrived," in Elk M1 Gold's list of voice vocabulary words.
Okay, cool!
As an alternatie to HomeSeer (since I don't have one and don't plan to buy one), I'll be programming my own application to receive text from Elk and process it through Microsoft Text-To-Speech.
Thanks!
HomeSeer is not a "one" but is a software package that runs on a PC. http://www.homeseer.comOkay, cool!
Thanks!
Very funny!
Thanks!
As an alternatie to HomeSeer (since I don't have "HomeSeer" and don't plan to buy one), I'll be programming my own application to receive text from Elk and process it through Microsoft Text-To-Speech.
