So I a light fixture I would like to put an insteon switch on, however like every fixture in this house none of the switches has a neutral wire.  This fixture is actually a bank of recessed lights and the insteon solution for handling no neutrals only support up to 300W which is about 200W short of what I need.  I was thinking that since the switch is a 3-way is it ok to rewire the traveler wire to be a neutral?  Is there and accepted standard to mark the red traveler wire with white tape to indicate it is NOT a traveler.
