apostolakisl
They do make shielded Cat5 which you can connect to grounding blocks. You could also put surge preventers on the cat 5 terminals. Personally I would put the Cat 5 in sealed conduit. By doing that you can easily pull other data lines if you like. Furthermore, it is not the natural direction of lightening to flow out of the ground and into structures. It can happen, but it is much more common to go the other way.
Your sprinkler must be done with the valves all together sitting right outside your house. Most sprinklers put the valves next to each watering area and run the control wires all around the yard following the main water supply to each zone. I probably have a couple thousand feet of sprinkler wire in my yard. If a voltage spike from lightening got into those wires, it would hop right across the micro air gap in those low voltage relays so I wouldn't put much faith in that.
Every day of our lives we have risk of a million things going wrong. Could lightening cause a surge because of this, I am sure it could. But I would venture to guess your chances of getting in a car accident driving to work are orders of magnitude higher with much worse consequence, and you still do that everyday.
