Premise Two Output HDMI Switch (Monoprice 4x2)
Motorola Premise
CuTN
Hi,
I'm trying to make a generic device for a Monoprice 4x2 True Matrix HDMI Switch v3 through rs232. I'm having problems getting it to track the two "Current Source" it seems like the default switch only tracks a single Source. How would one go about and add a second "Current Source" for output B?
Cheers
PS. New to the whole premise thing but am very interested in learning and getting up and going with it: seems very powerful and. I am also currently working on a 2-way serial module for a Krell HTS 7.1 Processor.
Cheers,
Just had a quick look at it and AISH my programming has gotten rusty. It might take awhile for me to trudge through all of this but I will definitely post my findings. This definitely looks like it can fit the bill though.
A few quick questions:
1) How does one go about forcing a class to gain inheritance of another class inside the modules section?
2) How was he able to make a class that doesn't have a base template? Every time I try and add another class I am forced to choose a class type
Cheers
PS:
I may put this to after I do a more simple one for a Krell HTS 7.1 Processor I have and use what I learn from that to this. Should I start a new thread or just continue here?
So here's an image of what you are probably seeing. You right click in the content area (center description area), but don't see the "Relationship" option.
The trick is you need to enable expert mode. Left click once in the content pain under any class under modules. Then hold ctrl+shift+alt+a all at once and then let go. You'll see a popup windows that says something like "Expert mode is now enabled." To get out of expert mode, you repeat the same steps.
Here's what you should see assuming you have expert mode enabled. To get to this menu, right click, then navigate as shown. The next step is to click "Inherited Class," and then browse to your object and click ok.
Making your own classes is the way to go as it can make coding much cleaner and organized.
