I’m desperate and am asking for your help. Previous weeks I’ve been trying to use the ELK 930 & 960 relay & timer combination to use an existing mech doorbell AND activate a wireless door sensor which will to sound a local “ding-dong” chime from my alarm panel. The panel's speaker essentially becomes a 2nd doorbell chime. Why? - I intend to replace the doorbell switch with an Alarm.com Skybell HD video doorbell (Skybell circuit only allows for one 16V, 10VA mech doorbell) after I've got the circuit integration working. Initially I got some good ideas from this forum on how to do this, but ultimately have been unable to make it work. I hope you can comment on my final config below:
I’m using the wiring diagram “Doorbell Circuit ELK 930 (A,'B to ELK 960 Hookup”. I’ve replicated the wiring precisely on a breadboard (I had a friend independently confirm the wiring is per the diagram) using these components:
- Typical Doorbell Transformer: 16V, 10 VA
- Mechanical doorbell with illuminated push button doorbell switch. This will be replaced by the SkyBell HD from Alarm.com
- To power the 960: a 12V, 1 AMP wall wart, striped side of cable wired directly to the "+" terminal on the 960. Using a voltmeter, I've confirmed that this wall wart creates "-12.4" volts
- Rectifier Diode “1N4004”, 1 AMP rated at 400V, diode stripe facing power source (not facing 960's blue terminal block)
- Wireless sensor 2GIG DW10-345 (default is N/C) "learned" into this zone, using wired leads (not reed switch). The leads are wired directly into the 960’s "N/C" and "Com" terminals. This sensor is powered by two coin cell batteries which I tested to confirm that they have a full charge
- On my 2GIG panel, I've programmed an unused wireless zone (Zone 020); Equip code 0862 which corresponds to this sensor, Sensor type: “23-No response” (won't send an alarm when activated), Sensor equip type is “contact”, Loop 1 of 3 selected, Sensor supervised: disabled.
When I power up both transformers and test the circuit, I'm getting illumination on the doorbell switch (which goes dark when I depress the switch as expected) and the mech doorbell creates the "ding-dong" chime as expected, but that's it. I’m not even getting the 960’s LED to illuminate when I press the doorbell switch, nor any chime sound from the panel. The panel programming seems to be correct because when I remove the DW10 sensor leads from the 960 terminals, the panel chimes once, regardless of whether there is power to the 960 or not.
Thinking I had a defective ELK 960, I returned and bought a replacement. Since the ELK 930 includes two doorbell sensors, I swapped one for the other and also replaced the diode - no change. The ELK components don't seem to be working (it's my fault); what am I doing wrong?
