LightenUP
So as the description says I had a controller in the Master bedroom with a Samsung Either plasma or LCD (not sure
The controller was affected by the TV to not be able to turn three units on. I moved the timer to the laundry and found undercabinet kichen lights were also causing noise so I phased the laundry breaker to the three already installed units and the noise was no longer an issue. However the customer wants it back in her room so the only solution I could think of was to filter that SAMSUNG tv with an x-10 plug in. I'll report later if she chooses to go with that solution uless she doesn't mind the controller staying in the laundry.
Also on another occasion I learned that if in the master bedroom they wanted a switch it was imperative to make sure to pic the correct neutral or the Arc Fault breaker would trip. I thought a neutral was all the same but apparently not.
Have any of you experienced theses issues.
