I've converted some of my regular 2-way switches to UPB and I am getting ready to tackle some 3-way and 4-way switches.  In general, I don't think I need to keep the n-way wiring as my switches tend to be located in banks so I'm figuring that I'll wire one load switch in a bank and provide the n-way functionality using a multi-rocker faceplate on the that switch.  I've only been using SA US2-40 switches.
There are two things I need to decide before starting. The first is the changes to the physical wiring. Everything I see is about how to wire a 3/4-way switch and nothing talks about unwiring them. I think all I need to do is wire nut the hot (black) wires and cap off the travelers at the points where I'm removing the switches. Is that correct? Is there any reason to prefer installing the US2-40 at the switch closest to the panel or closest to the fixture? Any suggestions as to the best way to document the removal so that it would be easy to put the standard switches back at a later date? I've got a label maker but I'm reluctant to stick anything into the box other than wires and switches.
The second is more cosmetic. I've got a number of boxes that will go from having multiple switches to just one switch. Anybody have a suggestion for the best way to handle. I could leave the non-working switches installed so the wall plate doesn't look odd but that I'm sure to get some pushback from the family about switches that don't do anything. I could wire in non-load UPB switches but I'd rather not spend $1000+ on switches that I don't really need. Are there blanks that I could just use with the existing wall plates? Any other ideas? All my existing switches are Decora.
Thanks, Bill
Thanks, Bill
