I have had an OmniPro installed for 10+ years controlling mostly a few lights via X10.
X10 on the fringe of the property was unreliable so I started to move to UPB approx. 2 years ago but life always gets in the way and I have never spent too much time on this project.
A walkway light had been controled by an x10 switch but stopped working when I switched to a LED bulb. I figure there was either not enough current to close the switch or the switch just was went bad.
I figured it was a sign to swap that switch out to a UPB Switch.
There are only 4 devices on the UPB network so far.
I have 2 motion sensors that are hardwired to a security light and also act as NO contacts to a UMI-32. The theory being that I could get a UPB signal when the security light goes on in order to activate other things.
The Omni Pro was reading the signal and then activating the walkway light via X10. So far so good.
I have not been able to get it to work the same way once I replace the X10 switch with the UPB switch.
Since the Motion Sensor (MS) and the Walkway Light (WL) now are both UPB I don't believe the OmniPro needs to be part of the equation. So I have been just trying to get the MS to control WL directly.
It isn't working so I know I am doing something wrong but I can figure out what.
As a way to test I programmed a switch to send out the same link that would activate the WL as I wanted the MS to do.
From the UPB Log.
Unit 002 - Test switch
Unit 066 - Motion Sensor
Unit 005 - Walway Light
When I hit the top rocker on the switch I get in the log
2,10/10/2014 00:19:59,2/2,198,Activate,2,Unit 002 - Garage - GarageSwitch,[multiple components],-3,Unit 005 - WalkWay - StepLmpPost,Preset 04,
and the light goes on.
When the security sensor activates it does the following but the WL does not come on.
2,10/10/2014 00:21:36,1/2,198,Activate,66,Unit 066 - Security - MotionSensor,[multiple components],-3,Unit 005 - WalkWay - StepLmpPost,Preset 04,
2,10/10/2014 00:21:37,2/2,198,State,66,Unit 066 - Security - MotionSensor,,0,,,2 0 255
I tested the device to device signal and it shows as excellent.
I have very little experience with programming UPB so I suspect it is something simple and stupid that I missed.
Any thoughts / suggestions would be greatly appreciated. I have the config file if that would help.
Thank you
From the UPB Log.
Thank you
