The LED does not work on the switch because it is not controlling a load directly. Like Robert said, the LED tracks the load (whatever is hooked up to with switches brown wire). In this example you are using the switch to just transmit a link to another device, the UFR. The US240 only has that 1 LED, it does not have individual lighted buttons and I think that is what you want in this case. If you use something like the HAI or PCS button controller, and program and individual button to control the UFR, then that individual button will light when on and blank when off. There is no multicolor LED that tracks links/scenes, only direct loads. Does that make sense?
