vc1234 said:
Oh, I see now. You meant the Configuration Class command that you can use to set/read device specific hardware parameters.
I've never bothered to read/reconfigure node parameters myself, but when i get home I'll see if I can do that to one of my devices.
So, I checked my devices. Only one of them (a Gen5 switch, Node 25) responds to the Configuration Properties request (0x70/0xE). Node 15 does not, although I can get its parameters(Toggle LED) in OpenZwave:
>>> for x in network.nodes[15].get_configs().values()
rint(x)
home_id: [0xxxxxx] id: [xxxx] parent_id: [15] label: [Toggle LED mode] data: [0]
The problem seems to be poor PC Controller implementation. According to a packet trace, PC Controller starts with the Version 4 Configuration Class command (0x70/0xE, Conf Properties) which is implemented in the newest Gen5 devices. Older devices implement 0x70/0x5 Get only (Version 1) and therefore do not respond to 0x70/0xE:
Good trace (node 25, controller 24):
2176983 [1093 14]home_id 18 51 09 0E 19
70 0E 00 01 A9 RSSI: -42
2176991 [1094 10]home_id 19 13 09 0A 18 90 RSSI: -79
2177048 [1095 17]home_id 19 51 01 11 18 70 0F 00 01 00 00 03 BC RSSI: -79
2177130 [1096 10]home_id 18 13 01 0A 19 98 RSSI: -41
2177189 [1097 14]home_id 18 51 0A 0E 19 70 0A 00 01 AE RSSI: -42
2177263 [1098 10]home_id 19 13 0A 0A 18 93 RSSI: -78
2177323 [1099 15]home_id 19 51 02 0F 18 70 0B 00 01 00 A6 RSSI: -78
2177400 [1100 10]home_id 18 13 02 0A 19 9B RSSI: -41
2177460 [1101 14]home_id 18 51 0B 0E 19 70 0C 00 01 A9 RSSI: -42
2177533 [1102 10]home_id 19 13 0B 0A 18 92 RSSI: -78
2177593 [1103 15]home_id 19 51 03 0F 18 70 0D 00 01 00 A1 RSSI: -78
2177669 [1104 10]home_id 18 13 03 0A 19 9A RSSI: -41
2177730 [1105 13]home_id 18 51 0C 0D 19
70 05 01 A4 RSSI: -43
2177800 [1106 10]home_id 19 13 0C 0A 18 95 RSSI: -78
2177859 [1107 15]home_id 19 51 04 0F 18 70 06 01 01 00 AC RSSI: -79
2177935 [1108 10]home_id 18 13 04 0A 19 9D RSSI: -41
2177996 [1109 14]home_id 18 51 0D 0E 19 70 0E 00 03 AF RSSI: -41
2178068 [1110 10]home_id 19 13 0D 0A 18 94 RSSI: -78
2178129 [1111 20]home_id 19 51 05 14 18 70 0F 00 03 09 00 02 00 00 00 B7 RSSI: -78
2178220 [1112 10]home_id 18 13 05 0A 19 9C RSSI: -41
2178281 [1113 14]home_id 18 51 0E 0E 19 70 0A 00 03 A8 RSSI: -41
2178353 [1114 10]home_id 19 13 0E 0A 18 97 RSSI: -79
2178414 [1115 26]home_id 19 51 06 1A 18 70 0B 00 03 00 4E 69 67 68 74 4C 45 44 53 65 74 E6 RSSI: -78
2178523 [1116 10]home_id 18 13 06 0A 19 9F RSSI: -42
2178584 [1117 14]home_id 18 51 0F 0E 19 70 0C 00 03 AF RSSI: -41
2178656 [1118 10]home_id 19 13 0F 0A 18 96 RSSI: -77
2178717 [1119 15]home_id 19 51 07 0F 18 70 0D 00 03 00 A7 RSSI: -79
2178793 [1120 10]home_id 18 13 07 0A 19 9E RSSI: -41
2178852 [1121 13]home_id 18 51 01 0D 19
70 05 03 AB RSSI: -42
2178922 [1122 10]home_id 19 13 01 0A 18 98 RSSI: -77
2178983 [1123 15]home_id 19 51 08 0F 18 70 06 03 01 00 A2 RSSI: -78
2179059 [1124 10]home_id 18 13 08 0A 19 91 RSSI: -42
Bad trace node 15:
2332708 [1130 14]home_id 18 41 01 0E 0F
70 0E 00 01 A7 RSSI: -41
2332715 [1131 10]home_id 0F 03 01 0A 18 9E RSSI: -74
