I would like to have a variable non-blocking delay controlled by UROM4. ie.
SET OP2[UROM4] 1
The PLC takes the code without error, but a code refresh shows;
SET OP2 1
If I use;
SET OP2[180000] 1
Everything works fine, and I get the expected three minute delay. The fact that the PLC generates no coding error on the first example, leaves the programmer with the understanding that all is well, until OP2 turns on for infinity!.Is this a bug? Am I doing something wrong? How might I program a UROMx variable non-blocking delay using UROM4? The problem exhibits itself on both 3.02.13 and 3.02.17 boards.
SET OP2[UROM4] 1
SET OP2 1
If I use;
SET OP2[180000] 1
