Hi Guys
Havent given up on the wireless moisture sensor...But got slightly side tracked...Im working on a handheld Moisture Probe which uses the Vegetronix vg400 moisture sensor and displays the raw data on a Sparkfun serial lcd....
I have also got a Vegetronix vg400 connected to RFXCOM Sensor which has an analog input... 0 to 10v....Using the RF receiver software its reading ok on reset but when reports normally its reporting much lower ..The analog power gets turned on only when reporting so i assume the reset much turn it on for longer...Might have to connect the analog power directly to the 9v battery...
Currently only the temp sensor + battery voltage of the RFXCOM Sensor are reporting to xPL once i get the analog input reporting i,ll install it in the garden and report back how its going...
More Soon
Frank
