Vegie Garden Mositure Monitor
FrankMc
Hi Guys
Thought some might be interested in my current project ..Vegie Garden Moisture Monitor ...
I currently have a 6 zone vegie irrigation system and decided to try and setup a system were a zone only gets watered if required..With my current setup all zones are watered sequencialy...
What im working on is an 8 zone system which when requested reports the value of the requested zone via a serial interface ....
The controller im using is the same type as i used for my vegie irrigation controller from Futurelec
http://www.futurlec.com/PIC16F877_Controller.shtml
The analog inputs will interface via a small veroboard......
My diy moisture probes consist of 2 3mm stainless threaded rods mounted on a plastic coupling...
There is a bi coloured led also mounted on the probe to display the moisture status...red = dry ...green = wet...The leds are connected to my probe monitor pcb....
http://www.hobby.armaghelectrical.com.au/page54.html
One of the xPL programmers is writing a plugin for it ,once thats done i,ll install the system and see how it goes.....
Normally i program my pics in assembler but with this project i have done it in Ladder logic...
http://cq.cx/ladder.pl
More Soon
Frank
electron
Administrator
Staff member
This looks very interesting! Do you have pictures of the probes installed? How long is the distance between the garden and controller?
FrankMc
Hi Dan
I haven,t installed the probe system as yet as im waiting for the xPL plugin so i can bench test....Will take some pics once that,s done...The longest distance cable wise is approx 5m..thats why i went for this setup...Im still looking into using a ds10 interface for my garden bed moisture monitoring ..
Frank
