I'm thinking of installing a sidewall exhaust fan on my 20x20 attached garage to cut down on the Atlanta heat in my southeast-facing garage in the summer. My thought was to install some intake vents on two panels of the garage door and a louvered exhaust fan on the outer wall to blow the hot air. During the day, the heat alone is annoying but once you put a hot car engine in there it gets out of control. Just getting it down to the outside air temp would be a huge improvement for me, and it would certainly make the garage more pleasant to be in.
The attic above is lightly insulated (~6" of blown cellulose), and I added a reflective foil layer to the door in an effort to control the situation a bit better. All this is well and good for helping with the radiant heat from the sun but that doesn't address the car issue in the slightest.
It'd certainly be easy enough to tie a Z-wave relay into a fan (like this or one of these) and have it kick on when my temp sensor hits a threshold, but I wanted to float my idea to see if there's something I'm missing. I'd sure appreciate any thoughts or ideas you might have.
Thanks!
Thanks!
