#include <stdio.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
const byte numBytes = 32;
byte receivedBytes[numBytes];
byte numReceived = 0;
int cnt = 0;
boolean newData = false;
void setup() {
Serial.begin(1200);
Serial.println("<Arduino is ready>");
// Serial.begin(1200);
lcd.begin();
void loop() {
recvBytesWithStartEndMarkers();
showNewData();
void recvBytesWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
byte startMarker = 0xAA;
byte endMarker = 0xAA;
byte rb;
while (Serial.available() > 0 && newData == false) {
rb = Serial.read();
if (recvInProgress == true) {
if (rb != endMarker) {
receivedBytes[ndx] = rb;
ndx++;
cnt = ndx;
if (ndx >= numBytes) {
ndx = numBytes - 1;
else {
receivedBytes[ndx] = '\0'; // terminate the string
numReceived = ndx; // save the number for use when printing
ndx = 0;
newData = true;
else if (rb == startMarker) {
recvInProgress = true;
void showNewData() {
if (newData == true) {
Serial.print("This just in ... ");
for (byte n = 0; n < numReceived; n++) {
Serial.print(receivedBytes[n], HEX);
Serial.print(' ');
Serial.println();
showGroupsOfBytes();
newData = false;
void showGroupsOfBytes() {
if ( receivedBytes[0]==0x4E ) { // change this to match your MTU it - it will display in serial print
if (cnt == 10) {
byte j = ~receivedBytes[6];
byte k = ~receivedBytes[7];
byte m = ~receivedBytes[3]; // If the power reading is way off, remove/add " ~ "
byte r = ~receivedBytes[4]; // If the power reading is way off, remove/add " ~ "
double voltage = 0;
double power = 0;
voltage = ( k<< 8) | j;
voltage= (123.6 + (voltage - 27620) / 85 * 0.4);
// Serial.print("voltage ");
// Serial.println(voltage);
power = (r<<8) + m;
power = 1.19 + 0.84 * ((power - 288) / 204);
// Serial.print("power out KW ");
// printf("power out %.4f",power);
// Serial.println(power);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("volts ");
lcd.print(voltage);
lcd.setCursor(1,1);
lcd.print("kw ");
lcd.print(power);
cnt = 0;
