Are you looking for a system that will simply display the same input on all displays at the same time? Or are you looking for something that can switch between mulitple inputs?
Another option would be to use a RBGHV switcher from autpatch or another manufacturer and use a breakout cable to separate the VGA to RGBHV. This is probably the only option if you need more than 1 concurrent output at a time.
