The manual valves will still be outside the house. It's a standard pressure balanced shower valve...
dont shower without one! So yes, the whole point is make sure the shower cant be used when
we are away.
The heating zone valves sound like a great idea. Ideally, they would be rated for drinking water too,
but I cant find a reference for that. The Taco valves mentioned above will close when power is removed.
That's fine by me. However, I am also curious about the current draw when opened. Since it's a gear
driven motor that has reached it's stop point, I'd expect the only current draw is from keeping it's
capacitor charged... shouldnt be much. The next concern is leaving the N/O relay that powers the
valve on for days at a time. I dont have much experience in that area either.
The valves on my pool (2" PVC ball valves) have an actuator that operates via three wires, one
common, one to open and one to close. I was really hoping to find something like that for 1/2" copper
and in the $50/valve range. At $100/valve the heating zone valves are my current first choice.
Dbeau-
Are you still planning on keeping the manual control valves on the outside of the house? If you are, then what is the chance that the power goes out, you are not home, and someone turns on the manual valve.
Are you trying to keep people from using your shower while you are not home?
