I've never needed a water softner until I moved into current home. The iron content was so high in this home that the water looked red from the tap and was turning the toilet bowels / clothes red. I had a local water softner company put in both a softner and a water purification system. (I'm cluesless)
An Autotrol Performa Prosoft with 960 serial control was installed.
In the last 6 plus years I've replenished it with 7 bags (40lbs each) of salt every 2-3 months. Not to bad (I though) but kind of a pain to carry the 7 bags of salt from the driveway to the basement.
Speaking to some of the neighbors they only utilize 1 40lb bag or less a month.Ha
So I decided to tweak mine but have no idea as the settings are somewhat cryptic.
Wondering if anyone out there has "tweaked" their softner. I was used to hard water before and still have a hard time dealing with the softer water.
It would be nice to tweak it in such a way to continue removing the iron and to be on the harder than the softer side.
The adjustments mention:
Level 1 parameters
Time of day - easy
Time of regeneration - easy
Hardness of water - value depends on a level II parameter
Salt amount - value depends on a level II parameter
Capacity of unit - value depends on a level ii parameter
Level 2 parameters
Refill controller
Brine draw value
backwash time
slow rinse time
unites of measure - easy
calendar overide - I put in a value of 7 to move the nightly backwash to that but its still going on.
reserve type
fixed reserve capacity
salt capacity change lockout
Finally factory defaults - wondering if I should start all over?
Level 1 parameters
Time of day - easy
Level 2 parameters
Refill controller
Brine draw value
backwash time
slow rinse time
reserve type
