I have two WC8 board version 2.3.8s. I have had nothing but problems with these getting the one wire sensors to work without constant reboots and lockups.
I have posted this issue over the the ISY forums (see topics under "CAI Web Control to ISY Integration") and performed the suggestions by the Cai Networks support team. When I saw this firmware update I thought I would try the update on one of them.
The other one is at my summer home and is currently sitting there locked up due to the one wire issue. Before this it would reboot itself at least once every couple of days and often many times in one day. (I have a program in my both my ISYs that track this) But when it lost the one wire sensor configuration it stopped rebooting itself and ran its other tasks perfectly. That is until a power interruption reset the one wire connections and it started rebooting itself as before, and finally locked up on December 4th, and has been that way ever since, since I am not there to cycle power it.
So on the second one which is here at home I tried removing one of two one wire sensors and ran it with just one. Since then it rebooted itself over 60 times in a months time.
I ran thehttp://ip-address/api/bootloader.cgi?start (yes, I substituted its ip address which is still the WC8 default) from the browser and it failed to connect but it did turn on the amber light.. I then ran the tftp.exe program and entered the IP address and the file update-PLC3-3-23.hex that I download from your site. When I select upgrade I get the error message "Unable to get response from server". After waiting I cycled power to my WC8 and it is now Bricked.
Any further suggestions would be appreciated.
