CAI_Support
Lou,Curious how the min readings on the red and the max readings on the blue correspond to what appears to be the true readings.
WebControl coutner is very accurate. However, since CPU is doing a few things all the time, it may miss a clock advance from time to time. The frequency measurment is divide the counter value by the time lapsed. Since we know the counter is accurate, the time could be actually longer by tiny bit, F = Counter/Clock, so the lower F is more accurate.
The variation is very small. When Ross talked about 20Hz jitter over his 120KHz clock source, the inaccuracy is 1.6/10000 or 0.016 percent.
