CAI_Support
In WebControl 3.02.16a/b firmware, there is a feature called WEBSET, that allows to set value to ISY device REST variables.
To use WEBSET feature to set value in ISY, you will need to configure a URL in the Notify Setup screen.
For example, in IP addressort field, enter:
192.168.200.123:80
in URI field, enter:
/rest/vars/set/1/15/
In Virtual host field enter:
AUTHBASIC: YWRtaW46cGFzc3dvcmQg
where "YWRtaW46cGFzc3dvcmQg" is base64 encrypted string for user name and password = adminassword
If your ISY99 user name and password is different, you can encrypt them on this page:
http://www.cainetwor...4-encoding.html
The in your PLC logic, enter this line:
WEBSET URL1 VAR1
when that logic execute, it will set variable 15 in ISY99 to the value of WebControl VAR1.
WebControl 3.02.16a/b user guide is online:
http://www.cainetwor...ide3-02-16b.pdf
If you have WebControl 3.02.16a firmware, we do recommend to send to us for firmware update to 3.02.16b.
Our special thanks to Dr. Lou and UDI for their support for developing this feature. Especially to Dr. Lou for his suggestion and allowing us to test on his ISY99.
192.168.200.123:80
WEBSET URL1 VAR1
