As I approach the end of the initial phase of the Westec 5000 to Elk M1G upgrade, I'm looking to do something with the Westec OAT functionality. This external keypad is currently outside of our garage overhead door. It was used both for arm/disarm/status of the W5K system as well as control of the garage door opener.
One thought is to build a simple interface between the OAT and the M1G. Perhaps via the ethernet/XEP. Or perhaps via hardwired signals. I'd use something like an Arduino module for the interface.
Does anyone have any technical information on the OAT? It has an eight wire interface to an AM5241 module. This module 'translates' the OAT protocol into the Westec keypad bus. The AM5241 sits on the normal W5K keypad bus. Since the AM5241 module is so old and uses 7400 series TTL devices, and since it's only a two layer board, I've started to reverse engineer the interface a bit. So far I know that he AM5241 supplies +12VDC and +5VDC to the OAT. There also looks to be a four bit bidirectional bus of some sort between the AM5241 module and the OAT itself. I've also gleaned from the W5K documentation that the four bit bus also somehow controls the four leds on the OAT. So I'm getting there..... My next step is to power up the OAT/AM5241 and 'scope the bus signals to see if keypress info is transferred somehow...
Anyway, does anyone have or know of a source for engineering level specs on the OAT (or AM5241 interface)??
FWIW, I'm NOT trying to emulate M1G keypad functionality on the OAT. I'd be happy to have arm/disarm, GDO control, and perhaps a door bell function. The OAT has one button that is the GDO control if you entered a valid system access code but is a door bell if you didn't enter a valid access code. Kind of a nice feature.
I know that I can replace the OAT with a wiegand (sp?) interface keypad and use the Elk-M1KAM. But that expensive and much less fun.
Thanks.
Thanks.
