A couple of points to ponder:
AHJ = Authority having jurisdiction
Start with you local code inforcement office. They should be able to tell you what codes have been adopted in your area or send you to who has authority. Electrical, building, or fire department...
Smoke detection
Ionization detectors can miss a slow smoldering fire.
Photo electric detectors can miss fast burning fires (Most have heat detectors)
Proper placement is a must. Learn about dead air spaces and out of path areas before ever recommending the placement of life safety devices.
110v w/batt ion (or sometimes PE) detectors are early warning detectors. Burnt toast should sound them. Ion detectors use a radioactive magnet to detect air born particals. cooking fish or fatty meat will set them off.
Early warning detectors are not allowed to activate automatic notification to the fire department.
System detectors are not early warning. They are designed to detect for a predetermined amount before tripping. They are designed and approved for activating automatic notification to the fire department.
Dual ion and PE detectors active an alarm if either sensor is triped.
So, you want to know the best way to go: system detectors or 110 ion detectors???
In my opinion, you need both.
Take the basic 2 story 3 bedrom.
110's top of stairwells and on each floor...
System detectors top of stairwells and on each floor. In every sleeping area. 135` fixed temp heat detectors in Attic furnace rooms garages and above sources of ignition, and any inclosed areas housing elect, equipment.
Audability has to be 100%. It should yell "FIRE". We don't need people hiding under the bed because they heard a siren. All sounders and wire should be aproved for fire alarm use. We don't want them to melt near the ceiling the one time you needed them or have them short out the system...
Of course the use of 110 ions in the sleeping areas is fine. Just not my recommendation.
OK, Let's talk CO detectors:
CO detectors rely on shape changes that take place to synthetic human tissue. The synthetic tissue has a life expectancy of 4 to 7 years. If the detector doesn't show a dead date then it is already dead (made before dead dates were required). Before disposing of it, take a hammer and smash it so it doesn't end up back in service. Most proffesional CO detectors have a replaceable sensor unit.
CO is a toxic gas that will build up in the body. It diplaces oxigen in your blood. It can run from a slow build up at low levels to a fast build up at high levels. Some people are more sensitive then others. Some get head ackes, some just become drowsy and pass out, but everybody can be over come by CO.
Getting someone effected out side in to fresh air asap is most urgent!
Driving them down the highway with all the windows open for an hour is a very good way to get it out of their system. AND YES calling 911....
So where does it come from and how does it move around?
CO is a product of combustion when fuel is burnned. An appliance that burns gas expells CO. If it is not vented propperly, wind blows down the vent... it will float in the house. CO is heavier than air, but in a heated condition it is lighter and will rise until cooled. Then it will sink. It will penitrate through sheetrock. That is why attached garages have to have 100% plastic vapor barrier between the sheet rock and the living areas.
There has been a lot of wars about placement and writing generic codes, so please use common sense. When code calls for the ceiling near the sleeping area (hallway) please place it clear of the landing but not after the HAVC intake. You want to be btween the source of the CO and the return duct...
I perfer wall mounting of CO detectors in these areas because if the air is hot near the ceiling then the CO gasses may never reach the detector! The ceiling becomes a dead air spot.
In sleeping areas the best place is a foot above bed hight. This didn't make code mostly because every sleeping may not end up with a bed in it...
Because CO can displace the air from the floor upward or from near the ceiling downward the detector would wake someone on the bed before over coming them. Personally I hate the thought of the detector on the ceiling activating long after the person on the bed has already surcomed to the CO.
When protecting an are with a source of CO (gas cook top, furnace, gas water heater...) you want to use the ceiling.
My guess is that if we went into a house owned by any of those that sat through these wars we would at least find a CO detector in their basement at about 2 feet off the floor.
Now for sensetivity. CO amounts of 35ppm over an extended time can poison someone. Code for the lowest sensitivity is 70ppm. So if you have occupants that don't ever leave the house, then don't count on the detectors 100%. Specially in months that the house is closed up (heat or AC).
System sensor smoke detectors are my favorite. Low bug probems. High immunity to dirt. Low false alarms. More than likely to activate when they die instead of just going to sleep. And I've installed and serviced thousands of them.
Funny, but the earlist modle smoke detectors I ever worked on consisted of one transistor and one PE emitor on refector. Can't recall the mfr? They worked. We replaced them due to cell phones tripping them...LOL
Properly installed fire detection saves lives!
