Photon
After a couple months of normal operation, my ELK M1 is becoming stubborn. I defined the magnetic switch in the door between the utility room and garage as normally closed, force armable. With the door open, the Ready light flashes on the keypad in the utility room, and the display reads "Ready Force." When I press the Exit button to arm the system, it renders a single low tone and then speaks "Intrusion Reporting-Intrusion-Intrusion Violated Utilility Room Door" and it refuses to arm.
I then close the door, the ready light stops blinking, and the display reads "Read to Arm." I can arm the system with the Exit button, and then disarm it with my code. Then I can open the door and get the same displays as at first, but now I can press the Away button and it reports it is armed Away Mode.
Is this another bug like the "leave for work" feature not working with delay2? Do I not understand the use of the Force Armable feature?
Software 5.1.8.
Regards. . . . John
Software 5.1.8.
Regards. . . . John
