jmed999
Currently my XEP is plugged into an outlet using the transformer that came with the XEP.  In this setup the XEP goes dead during a power outage.  I want to allow the XEP to be on backup power and still send signals during a power outage.  I have IP monitoring and cell (Uplink 2500) as a backup.  My router and modem are on UPS.  So I decided to do this...
1) I bought a P212S to use with the currently being used XEP. I also bought a transformer, low battery cutoff, and will buy a battery and surge protector. This will allow the XEP to run even during a power loss.
2) I'm now wondering if I should just meter out the barrel connector and power the XEP via the power outputs from the Elk control panel itself. I could return the P212S, transformer, and low battery cutoff. I also wouldn't need an additional battery and surge protector for the XEP.
Besides #2 being cheaper what is the difference in #1 and #2? Is #1 better? If so how?
Thanks for your help!!!
PS. I currently have the NAV keypad, wireless receiver (Elk-M1XRFEG) and 20 Watt speaker (Elk-73) connected to the M1 control panel. I will be adding smoke and carbon monoxide detectors soon. Not sure if those are powered from the M1 control panel or not. I will likely also add another speaker for the attic.
