I have made some previous posts on this subject , however I'm probably more confused than ever on which HAI stats to get.
I purchased 3 RC 100Bs from 2 different online dealers after explaining what I needed .
Well, the HVAC guy came by today to connect them and work on a few airflow issues.
One of them appears to be just what I need and is working fine with the Heat Pump that heats and cools the upstairs.
Downstairs we have 2 Dual Fuel (NG furnaces tied into Heat Pumps). He the stats wouldn't work properly with the DF system and would not turn the heat pumps off when the furnace was running.
So now I have to hopefully return the other 2 unopened thermostats and replace them with another model. The question is which one ?
These are units single stage heat pumps with a high efficiency Furnace.
It would seem to me that if I have to go with the more expensive newer HAI stats , that the HAI RC 1000WH is what I will need to go with.
If anyone has any input on this , I will appreciate your input , as I want to be sure and get the correct stats this time !
Thanks !
Thanks !
