Should this issue be logged to Elk?
Just tried to contact the Elk on the network using my iPhone, with basically the same result. I get the login name and PW challenge, but don't even make it to the security code screen. Elks do NOT like Apple anything, it seems. Man, did MSFT buy in or something??!!
Will keep you posted...
The M1 protocol is open, anyone can write their own interface I actually started something in Flash, but got tired of coding BTW, have you tried Camino yet?
I had a brief discussion with Brad a year or two ago and did some debugging. I don't remember exactly what the problem was, but it was related to the authentication process. The work-around is to disable the username/password, then it will work just fine with only the user code. Unless you are in a special situation it is not likely anyone is going to be hacking your interface. Works great for me once I removed the username/pw. Only remaining problem is the sizing of the output panel with the mac java engine, a note somewhere referenced this as fixed but still a problem for me.
Thank you very much for the post! Disabling the html user/pass in the Elk M1-EXP configuration fixed the connection issue! Specifically, I am connecting via Firefox on Ubuntu Jaunty with the Sun 1.6.x JVM and applet plug-in installed. I can now FINALLY fully utilize the very expensive piece of hardware I have cursed many times over the last few years. I have to admit, the lack of support of this component made me really question if I would continue to purchase Elk hardware in the future. At the very least, I would ask Elk to please post a bold-faced service bulletin on the install support page notifying purchasers of this component of its limitations.
icellama21, you are my hero!
I imagine that the ekeypad product will eventually make its way to the mac OS too. Depending on how jayson designed it, this could be as quick as a few hours, worst case is still not that hard as most of the work should be portable. I was considering this as an open-source project a while back but no one was interested, and then ekeypad came out, which is much better than anything I have. My current project is trying to make an elk plug in for the apple TV(unofficially of couse). I've just got the thing hacked and am playing with a sample plug-in now. PM me if anyone is interested and I'll keep you in the loop for updates.
As someone else pointed out, I think the key here is the user authentication. I didn't have it enabled, which would explain why it worked for me. Do you have it enabled UJ?
