You guys are giving me a lot of good things to think about.
As far as the speed and switching goes, the AudioAccess amps I'm using are powered on a per channel basis via line level input. When the Elk wants to speak, I will have to have the CQC system switch the inputs and couple all of the outputs together. Being serial, there will be some time lag in setting up the Autopatch, not much I hope. Then, any of the amp channels that are not already running will have to power up, that's my main concern over losing the first part of the announcement and my question as to whether I can delay the ELK message with a rule that enables me to setup the Autopatch switchers and perhaps send a dummy signal to the AudioAccess amps to get them powered up.
I will check the impedance on the piezos. I believe they run around 110db, so I'm not sure how many I would need to use. I suppose I could use another channel to switch 12v to them.
Spanky, are you saying I wouldn't need the piezos or horn/bell with those little single gang speakers or are the strictly for voice announcements? Any chance of sneaking us a picture?
I just ordered 24000' of wire, anybody want to be my new best friend
Brian
Brian
